Ok... Those with... B6 GIAC / TIP / Boost Gauge... Help me out
ok... im going to settle this once and for all... what is your peak boost becuase mine is about 14-15 max throughout all gears and it drops back down to 8-9 at the end of each gear... sound familiar??... the guy insists that i have a malfunctioning boost guage? possible my software got like messed up half way though its install?
ive been dealing with it since summer and its starting to get me angry again
RE: Ok... Those with... B6 GIAC / TIP / Boost Gauge... Help me out
With my Giac X chip I spike 23/24 and hold around 18/19 and settle around 15 by 6k... I have a stock N75... However in 3rd (Passing gear) on the freeway when I gun it I only hit 10??? I doesnt seem to pull that hard, however when I ease into it it pulls pretty nice
I got b6 manual and I spike at about 18 and hold 10-12psi. Your boost gauge may be off. It should be reading about 20 vacuum at idle. When I first hooked up the boost gauge it was only reading 15 vacuum at idle and I thought it was off but then I figured out it was a boost leak (bad leaky DV) and when I fixed it gauge read 20 at idle and spiked at 18
ORIGINAL: StepUpProductions
soo thats the thing i have never spiked anywhere near 18...
Of course you/they might have to completely rule out any boost leaks or other problems than the GIAC file that might cause your problem.
8-12 psi is too low. GIAC and APR use 1bar+chips and 12 psi is like .8 bar.. so anything less would not be right even in high rpms. I can see falling off to 15 or even 14 psi, but the even thought the k03 loses its breath in high rpms, it shouldnt fall on its face like that... Especially if you have a high flow exhaust and or fmic.
thanks, thats really helpful... ive been hearing bad things about my local tuner lately so maby il speak to GIAC directly and find another local GIAC dealer and have them help me out... ive pretty much ruled out boost leaks because with the VAG-COM i had my buddy sit in the passanger seat and read me off my BAR boost request leverls and boost output levels and they were pretty equal + or - .01 here and there so... il have to investigate this
However I my vac goes to like 25... Does that mean I have a boost leak? because I still spike high?? I dont get it.. I know im suppose to be around 15 20 but 25..?
ORIGINAL: socal_A4
Soley4pres
13
06-05-2012 08:39 PM
Yuppie
05-05-2009 11:52 PM
s4me
05-18-2005 08:39 PM
