One more question
Old Dec 27, 2007 | 01:15 AM
jrock's Avatar
Default One more question
Does the deep side of the crankshaft pulley face towards the front or rear of the car?
Old Dec 27, 2007 | 01:16 AM
auditech79's Avatar
Default RE: One more question
The deep side faces the radiator, the bolts aren't long enough to work the other way.
Old Dec 27, 2007 | 01:17 AM
auditech79's Avatar
Plus its keyed
Old Dec 27, 2007 | 01:18 AM
jrock's Avatar
well it keeps moving when i try to tighten the bolt and now i finally got the timing belt on but the marks arent matching up and i think it is because the pulley is moving around when i tighten it.
Old Dec 27, 2007 | 01:20 AM
jrock's Avatar
o woops i meant to say the camshaft pulley my bad.
Old Dec 27, 2007 | 01:21 AM
auditech79's Avatar
You just didn't get the timing belt on right, take it off and try again. The trick is to tension it around the crank and cam first, then slip the belt on either the tensioner or water pump (if on the timing belt)
Old Dec 27, 2007 | 01:23 AM
jrock's Avatar
ok thanks i am going to give it another shot now that i downed a beer but am i right that the camshaft pulley has the deep side facing the radiator also?
Old Dec 27, 2007 | 01:27 AM
auditech79's Avatar
The cam pulley should say front on it, but no the deep side should be facing the motor.
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
