Outside temp?????
Old Dec 2, 2006 | 11:57 AM
Turnfast03's Avatar
Default Outside temp?????
I read in the owners manual that the outside temp will read "slightly" higher when the car is sitting still or at very low speeds, but it was 76 degrees outside and the gauge read 94 degrees. To me that is not slightly higher! Does anyone know where the sensor is located in the engine bay so I can move it so it will read more accurately.
TIA
Old Dec 2, 2006 | 12:20 PM
drroy's Avatar
Default RE: Outside temp?????
It picks up engine heat, it will stabilize after you have been driving a short distance.
Old Dec 2, 2006 | 12:33 PM
dankhound's Avatar
the sensor is located between the front bumper and the radiator. Make sure the bracket that holds it in free space hasnt broken. It often beaks and if it falls on something hot it will read incorrectly.
Old Dec 2, 2006 | 12:41 PM
Turnfast03's Avatar
Awesome, thanks I will look there.
Old Dec 2, 2006 | 01:49 PM
cary12's Avatar
ORIGINAL: Turnfast03
TIA
76 degrees!! You bastard! It's 10 degrees here right now!!!
Old Dec 2, 2006 | 01:54 PM
The Bishop's Avatar
To be more specific it's on the bottom front of the radiator attached to the bottom of the power steering fluid cooler.
Old Dec 2, 2006 | 02:29 PM
Turnfast03's Avatar
ORIGINAL: cary12
TIA
10 degrees in Kansas! Ouch!!! Sorry to hear that! That storm that plowed into you guys is finally here, not to cold about 65 today with a drizzle!
Old Dec 2, 2006 | 03:03 PM
The Bishop's Avatar
You guys have it easy. It was -18 degrees here yesterday.
toboater
Oct 26, 2010 12:15 PM
zer0vette
Jul 21, 2010 10:30 PM
kbrookst
Oct 24, 2009 06:37 PM
danmcc86
Feb 12, 2009 11:49 PM
