overheat oil !!!
Old Jan 4, 2007 | 02:47 AM
BadLuckAudi's Avatar
Default RE: overheat oil !!!
its sounding more like its just the oil temp sensor Id replace that before you mess with anything else
Old Jan 4, 2007 | 01:20 PM
NuYorka103185's Avatar
Yeah mine does the same thing, the oil temp will spike while my engine temp remains fine and there is no loss of performance. Then it will just drop to normal. Sometimes it does not read at all. For me my money is on sensor. Is yours always at 350 or does it seem to fluctuate violently like mine?
Old Jan 4, 2007 | 02:14 PM
sautsinaga's Avatar
yes, my engine temperature remains fine,but my oil temperature increase constantly until it reaches over 350.
It happened just after I top off my engine coolant reservoir.
I checked my oil level and it is still fine.
so yeah, im not really sure whats wrong and i dont think its the sensor.
Old Jan 4, 2007 | 03:35 PM
acetrebo's Avatar
If your engine itself is not running hot, then it is most likely the oil temp senor itself that is the problem.
If your oil was really that hot, then your engine temp would be way up there too.
The adding of coolant, and the probelm you are experiencing, are just coincidence. If your engine temp is normal, there is nothing wrong with the coolant system. So, change the engine oil temp sensor. thats the first step.
Old Jan 4, 2007 | 03:41 PM
new2me's Avatar
Cant you just eliminate a problem by just pointing a laser thermometer on a oil line or oil pan and see if its indeed at 350 degrees?
Old Jan 5, 2007 | 02:30 AM
sautsinaga's Avatar
ive been driving the car around for about 1 hour today. stop and go of course.
and it seems that the oil temperature back to normal.
This step that I took might fixed the problem:
open the coolant reservoir
start squeezing the big black hose that is connected to the reservoir. Thanks godfather.
PS: DO NOT OVERFILL YOUR COOLANT'S RESERVOIR!!!
Old Jan 5, 2007 | 03:03 AM
wood_e's Avatar
If you overheat your oil your engine won't last long... check out your temp sender
audiaa6.2000
Aug 4, 2016 09:35 AM
Ben Mann
Jun 6, 2012 01:28 AM
boosted_a4
Jan 10, 2010 01:09 PM
cary12
Oct 6, 2006 04:44 PM
cary12
Oct 5, 2006 07:41 PM
