Overheating :(
Old Nov 7, 2007 | 11:19 PM
jinnyboo's Avatar
Default Overheating :(
So then, today i went on the freeway and i had it in fourth driving with a friend, then we were playing around and i downshifted to third, and it went to about 5700-5800 rpm, and i drove like that for about 5 seconds, then shifted to fourth, then fifth, the next thing i notice is i hear a beep, i had pictures blocking my cluster so i didn't see the boat or whatever, so then i remove the picture thinking i am low on gas since i was low on gas, then i saw the boat and looked at my temp and it was at HOT all the way at the end, i pulled over ASAP and turned the car off, i waited for about 40 minutes and drove the car back about 20 miles. does anyone know what went wrong?? my water thing was boiling for awhile until i took the cap off, i hope i didnt crack my head or something maybe my thermostat is broken??
any help appreciated, i'm going insane right now. please and thank you.
Old Nov 7, 2007 | 11:29 PM
MistaGanja's Avatar
Default RE: Overheating :(
Dang, well first off dont have pictures on ur cluster, but i would have the thermostat water pump kit replaced if you havent done that recently and alos a coolant flush and re-fill.
Old Nov 7, 2007 | 11:33 PM
jinnyboo's Avatar
eh i had it off, i was cleaning out my car today before a vaccum and car wash and left them there for awhile and just forgot about them, yeah i was seaching it and people said the 1.8t's are "infamous" for overheating, and that they change the water pump alot.
hmm??
Old Nov 7, 2007 | 11:46 PM
chaos92287's Avatar
by the "boat" you mean that thing that kinda looks like an F floating in some water? thats the low coolant warning. check your overflow and see if the level is low.
Old Nov 7, 2007 | 11:49 PM
jinnyboo's Avatar
oh i see,
well you know how that container is half coolant and half water? how do i know what i'm low on, do i just fill that thing up with water?
Old Nov 8, 2007 | 12:01 AM
chaos92287's Avatar
your probly gona be low equal amounts of g-12 and water, so just add a 50/50 mixture. if there is low coolant, then you might have a leak. see anything on the ground?
Old Nov 8, 2007 | 12:41 AM
jinnyboo's Avatar
there were like 3 drops on the ground, i coulnd't tell what it was, it was at night. but other than that there was nothing on the ground. i don't know if my thermostat went out, or if i need my water pump replaced. any ideas?
i might just need to fill that thing up with water.
Old Nov 8, 2007 | 12:53 AM
jinnyboo's Avatar
is it a good idea to put water in my car when i wake up tomorrow? its been sitting there for about an hour now and its gonna sit there for another 10hours+ is it a good idea to fill the g-12 thing up with water till its full? other than that how much would the dealership charge to change the water pump??
thanks man your a real help.
Old Nov 8, 2007 | 12:58 AM
chaos92287's Avatar
only put water in if its low. is it? reason why i asked earlier is cause if the coolants low than thats what caused the engine to overheat, and means you have a coolant leak. if the coolant level is fine, then it could be your water pump, thermostat, or coolant temp sensor.
Old Nov 8, 2007 | 01:01 AM
jinnyboo's Avatar
its not low, and its not full. i don't remember what it was at, but i'll check in the morning.
how do i know if i have a coolant leak? if theres leaks on the ground??
that g-12 thing was boiling until i took the cap off. so iono?
i'll check it with a dealership tomorrow if i fill the thing up with water and its the same thing.
thanks for the help chaos.
much thanks!
