Oxygen sensor Please help!!
Old Feb 1, 2005 | 08:48 PM
Jestnomen's Avatar
6th Gear
Default RE: Oxygen sensor Please help!!
Go get it scanned, it's free. The original codes you have aren't correct.
Old Feb 1, 2005 | 09:20 PM
jasong's Avatar
No the codes are write, they were just written down incorrectly, it's easy to match them up if you use the chart. Either way, if those codes are correct, what do you suggest I do?
Old Feb 1, 2005 | 09:33 PM
Jestnomen's Avatar
6th Gear
P0442 - yeah that one is usually the fuel cap as you stated.
P1128 - Long Term Trim Mult, Bank 1 System too lean. Do you have a V6 or 1.8t? on the V6, bank 1 = passenger side.
How many miles do you have? If you above 80k or so, I would replace the pre-cat O2 sensors.
Old Feb 1, 2005 | 09:42 PM
jasong's Avatar
yes, it is the 1.8t, with about 80,000
Old Feb 1, 2005 | 09:46 PM
Jestnomen's Avatar
6th Gear
I would def start by replacing the pre-cat O2 sensor. You'll get better fuel mileage too!
Old Feb 1, 2005 | 09:55 PM
jasong's Avatar
Do you think that could actually affect the idle though? Should I replace the fuel filter also? Do you know how to change it? It looks like the whole gas tank needs to come out.
Old Feb 1, 2005 | 09:58 PM
Jestnomen's Avatar
6th Gear
Yes the O2 sensors CAN effect idle. When one of mine went bad the car would shudder at cruising speeds and would not idle very good. Here's a tech writeup on the fuel filter change:
http://www.audiworld.com/tech/eng49.shtml
Old Feb 2, 2005 | 04:51 AM
  #18
brrman's Avatar
I have a bad o2 sensor right now. My idle is jumpy when I slow down to pull into my garage,
Need to replace in a week or so.
Old Feb 2, 2005 | 12:15 PM
  #19
CRAZYHAWK's Avatar
At 80K mi. , you should replace the spark plugs and air filter.
Old Feb 2, 2005 | 12:20 PM
  #20
dudley doright's Avatar
You have a vacuum leak somewhere.
