P0004 Engine Code
Old Jan 24, 2014 | 07:31 PM
arcwcb's Avatar
Default P0004 Engine Code
It's gotten super cold here and the roads have been pure slush and salt. The other night while driving, the CEL light came on. When I checked the codes, it gives me P0004 and P0000. Any idea what the fix is for these? I can't clear them and searching hasn't produced much info on them. Thanks for the help!
Old Jan 25, 2014 | 09:59 PM
markymarc's Avatar
I'm going to guess you are using a generic code reader? If you used a VAG it would throw the Audi fault code which would help solve the issue. P0000 means there are no codes to read generally or the reader you are reading isn't reading the OBD2 port correctly. I'm going to guess your scanner is malfunctioning on the p0000 and you are not using a VAG?
The P0004 means:
16388
Fuel Volume Regulator Control, Circuit High
Has your ECU been remapped?
xristos.greece
Aug 13, 2017 08:24 AM
HumbyWumby
Apr 4, 2013 05:44 PM
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
spinedoc
Nov 3, 2008 12:12 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
