partial throttle stall?
Old Jan 19, 2006 | 12:47 PM
quattrosedan's Avatar
Default RE: partial throttle stall?
Mine doesnt actually shut the car off. It jerks really bad when I let off the throttle, and then resumes normal operation. I dont get a cel, im not sure what a epc light is, but I dont think i get it either. And this doesnt just happen sometimes. If I get into more than 5lbs. of boost and let off, it will jerk. I am going to inspect my vacuum lines and dv soon. I also have a problem that if i shift hard, when I floor the next gear, it feels like about a full sec of lag then starts pulling again. that is what makes me believe it is the dv.
Old Jan 19, 2006 | 12:54 PM
techbod's Avatar
I can only think air/vacuum/inlet/turbo linkage
Old Jan 19, 2006 | 01:04 PM
onepoint8tee's Avatar
ORIGINAL: quattrosedan
This is what im talking about in my "cheapest bailey or forge" post.. Im experiencing the same thing, which makes me think its my dv too. I say you get a new dv and let me know!
except i called it a surge, its more like slight lag when boosting high and shifting gears.
Old Jan 19, 2006 | 01:22 PM
techbod's Avatar
surge is a different thing all together, when asking for advice as much info on your car is required, don't just show a picture of your car it might not be yours not that im bothered
Old Jan 19, 2006 | 01:33 PM
ORIGINAL: avant80@2.6
Yes, thats why i edited the post correcting myself in saying "except i called it a surge, its more like slight lag when boosting high and shifting gears" I dont know if your talking to me... But yeah a surge is different than lag... all together.
Old Jan 19, 2006 | 05:04 PM
All right, well i have the elim gtrs with stock inlet pipe, and stock airbox with stock air filter. Is it possible that it just cant suck enough air and after a shift has to rebuild the boost?
I have a new 3" inlet pipe on the way that gets rid of the step down on the turbo inlet, so if that doesnt fix it, I am going to smoke test it then if thats not it, it almost has to be the dv.
Old Jan 19, 2006 | 06:01 PM
Jeff's Avatar
Zombie Defense Force
sounds like a dv to me, maybe it is not shutting when u get back on the gas so it takes a while to build boost then it shuts exagerating the "lag" feel
Old Jan 19, 2006 | 07:05 PM
  #18
alright, i will check that this weekend. Thanks for the help guys!
Old Jan 19, 2006 | 07:56 PM
  #19
drkenan's Avatar
Hey man I had a very similar post around 2 weeks ago and I finally got around to figuring out what's wrong. In my case I think (still not 100%) that one of my knock sensors is giving an erratic reading and thus the ignition timing on cylinder 4 is retarded. If you have a vag-com you can run tests on blocks 20 and 26 (I think...it's somewhere around that) at WOT and see if you get any strange readings. Cylinder 1 & 4 knock sensors and cylinder 2&3 should give very very similar readings. If there is any discrepency, this could very well be your problem.
Old Jan 19, 2006 | 08:00 PM
  #20
ORIGINAL: drkenan
Im gunna scan for codes tonight. If i dont get anything, ill probably order a new 710n and hack open my old one to see what shape the diaphram is in.
Even though you werent replyin to me.
