Please Help!!
Old Nov 29, 2007 | 02:34 PM
monterey red's Avatar
Default Please Help!!
I'm writing on behalf of a friend. She owns an A4 with AWD. It's a fairly late model sedan with a powerful turbocharged engine. Anyway, she did not get an owners manual with the car and now she gets a warning light consisting of a yellow or amber circle with 3 or 4 circular dashes on each side. I believe it might be a brake warning light. I would appreciate information on what this light means, what to do to address it and how to make it go away....
Thanks very much in advance for your kind help
Old Nov 29, 2007 | 02:41 PM
99A4NOW's Avatar
Default RE: Please Help!!
This is only a guess, but I'd say low brake pad warning. Hard to say without seeing it
Old Nov 29, 2007 | 02:45 PM
Rob_B's Avatar
Sounds like the low brake pad warning light. Change the pads, and make sure you use the ones with sensors in them.
Old Nov 29, 2007 | 05:38 PM
1Move's Avatar
byt he sounds of it this is definetly brake pad warning, change the pads and use ones with sensors on them otherwise the warning wont go away!
Old Nov 29, 2007 | 06:27 PM
CRAZYHAWK's Avatar
(0) add brake fluid or warn front brake pads.
Start by adding brake fluid (DOT 4).
