Please Help me, I dont kno whats wrong!?!?!
Old Apr 15, 2007 | 02:11 AM
JasonG2423's Avatar
Default Please Help me, I dont kno whats wrong!?!?!
I have a 2001 1.8T quattro, and just yesterday i pulled up to an intersection and i was pullin out in 1st gear and as soon as i let the clutch out i pushed it back in and my car struggled and shut off. Now this happens everytime i repeat that as long as the engine is warm, if the engine is cold itll never do it, so everytime the engine is wamred up i can repeat this process and itll struggle than shut off. would anyone know what could be wrong with it? i tried lookin for vacum leaks and didnt seem to find any, i replaces some of the hoses with the threading around them but still didnt work. I havent replaced my fuel filter or plugs or wires or coil packs since ive had the car for 4 months and as far as i kno the people before me never did either. My car has 80K on the clock. please help me!
Old Apr 15, 2007 | 02:20 AM
turbo kraut's Avatar
Tech Guru
Default RE: Please Help me, I dont kno whats wrong!?!?!
maybe a clutch
Old Apr 15, 2007 | 10:16 AM
david9999's Avatar
Have the engine checked for codes at autozone and post them back here.
Old Apr 15, 2007 | 12:49 PM
CRAZYHAWK's Avatar
+1 ^
I had to replace the MAF at 87K mi.The car would not idle. I had a code
that indicated it was bad.
Old Apr 15, 2007 | 01:06 PM
JasonG2423's Avatar
well see the car does idle, it only happens when the engine isnt cold anymore and than if i pull out of an intersection and say maybe a car was coming and i would push the clutch back in and than hit the brake itll struggle and shut off for an example. and it only happens like that in first and reverse, i can still take off it jsut does that in those 2 gears, not in any other, i mean i can coast to a stop in neutral in every other gear and it wont shut off.
Old Apr 15, 2007 | 01:13 PM
quattrosedan's Avatar
Sounds like a vacuum issue, not a clutch. Follow david's advice and have it scanned. Post the codes up and we will probably know.
Old Apr 15, 2007 | 07:13 PM
JasonG2423's Avatar
can i get it scanned if my check engine light(or any other error light) isnt on?
Old Apr 15, 2007 | 07:19 PM
techbod's Avatar
yes its called soft codes and dosnt set the CEL on till it does it 3 times then its a fault
ryanramalho
Jun 1, 2014 09:08 AM
asalian
Sep 25, 2010 03:39 PM
patrixx006
Dec 17, 2009 01:39 PM
morrisonjd84
Oct 23, 2007 10:08 PM
auDi1.8TQ
Feb 17, 2006 02:39 AM
