Please help... sooo frustrated
Old May 14, 2007 | 09:21 PM
B5luver's Avatar
Default Please help... sooo frustrated
Well.... I finally got around to it today and installed my new boost gauge and Forge 007. Took it for a ride and the gauge didn't register any boost. The gauge reads in bar, at idle it was about -.8 and then when driving it would read 0, at one point in second gear the gauge did register about .2 bar but thats it. My car is a 00 A4 1.8T fwd tiptronic, it has almost 152k miles and RARELY will burn coolant when idleing, but like it said its only happened about 4 times in the 6 months that I've owned the car. Any ideas, I really need help figuring this one out
Old May 14, 2007 | 09:38 PM
TeeterTawter's Avatar
Default RE: Please help... sooo frustrated
installed backwards. loose clamps. leaky gauge. also check the vacumm lines to and from ur boost gauge.
Old May 14, 2007 | 09:53 PM
B5luver's Avatar
boost gauge is electronic and has a sender unit... those lines are all tight, and i thought it didn't matter how the dv was installed, but put it in the same as factory...
Old May 14, 2007 | 11:07 PM
ohh electronic boost gauge fancy, i have no idea how those things work. i perfer mechanicle devices, alot easier to deal with.
Old May 14, 2007 | 11:20 PM
B5luver's Avatar
well the vacuum line is hooked up to asensor, and that sensor then sends a signal to the gauge. I would have prefered mechanical, however this gauge matches my interior perfectly, which is what I wanted... any ideas though... anyone???
Old May 15, 2007 | 07:50 PM
B5luver's Avatar
Ok... I have a very well understand of how cars work and what not, I just don't understand this one... my car feels no different now after the install than it has over the past 6 months since I bought it... the only thing i can think of is that the sensor is bad, but how could it register vacuum correctly and not boost
Old May 15, 2007 | 09:42 PM
JETSPEED333's Avatar
SoCal Crew Member
you should only be seeing about .3-.4 of a BAR for 5-7lbs of boost
and cars don't really "burn" coolant...
i bet it's your resevoir bottle..... does it look old and brown?
if so replace it.
in 2000 the 1.8t i belive were boosting 5 or 6 lbs of boost... then in 2001.5 they boosted 7
pretty sure... don't hold me to it
does your car feel like it is running good? does it feel like it's lagging?
get a chip.... then you'll see a whole bar....bar and a half.... or just get a psi boost gauge...you can find one that matches your int. there out there.
Old May 15, 2007 | 11:29 PM
B5luver's Avatar
Weellllll... the car feels like it always has, kinda sluggish to me because I'm used to peppy, very responsive Honda's. As for full boost on a gauge, when would I hit full boost? Maybe I should try and borrow a psi boost gauge and test with that?
Old May 15, 2007 | 11:43 PM
SoCal Crew Member
.3-.4 BAR = 5-6 lbs BOOST
get a new gauge...that one's going to be no fun...
and get chipped....world of difference for the 1.8T
Old May 16, 2007 | 04:08 PM
B5luver's Avatar
Well the whole reason I got the boost gauge is because I am going to be doing the zener diode mod, so once thats done it will be "fun". I just guess I thought it boosted a little more than that factory... oops.
