Porsche Brakes
i would go with stop tech over any bbk company on an audi. porsche brakes were not built to work with the audi brake system where stoptechs were desidned for the audi. however as tom showed porsche will work
You must be very careful when using the porsche calipers. They are specifically designed for the weight distribution on the porsches which is WAY different than the Audi's. Even on my 911 (964), when I change the calipers I must rebalance the system using different bias valves. It will also effect the ABS system. Not that it can't be done, just a lot of "engineering" work would be required to do it properly.
........go with the 15inch Brembo BIG BRAKE Kit, then you will have brakes bigger then some peoples rims.
