Possible error in Bentleys on control arm gap
Old Jan 28, 2007 | 12:36 AM
IDUAAUDI's Avatar
Default Possible error in Bentleys on control arm gap
'98.5 A4 1.8T QTIP..... My Bentleys shows the gap between the upper control arms and the mounting bracket to be 47MM. When I removed the originals the gap was much larger, but I went ahead with the 47MM. After installing I found a write up in the Tech Section that refers to a 57MM gap (closer to what I measured on the originals). Is my Bentleys wrong? And if so should I go back and correct the gap?
zartoop
Dec 3, 2014 02:30 AM
jj fad
Jun 27, 2012 04:35 PM
mdsulli
Sep 4, 2007 09:27 PM
dmansoor
May 10, 2007 12:22 PM
kerosene
Jan 18, 2007 04:06 AM
