Possible Fuel pump issue???
Old Sep 20, 2006 | 03:53 PM
daghstdrummer's Avatar
Default Possible Fuel pump issue???
I have a 02 a4 1.8t i got it in july and got a carfax buy back guarantee.. the only thing thats bugging the hell out of me is a noise comming from the rear right side of the car.. its a whirring noise that comes and goes but if im on the highway for example it will stay on until i turn the car off... i took it back to the dealer and they can't find anything wrong? ami going crazy???
Old Sep 20, 2006 | 04:02 PM
techbod's Avatar
Default RE: Possible Fuel pump issue???
when it happens how much fuel is in the tank??
Old Sep 20, 2006 | 04:27 PM
dafrazi's Avatar
Fuel pumps on A4's are loud. I can almost always hear my fuel whirring away.
Old Sep 20, 2006 | 04:28 PM
it does not matter how much gas is in the tank i happens when its full half, empty or anywhere in between
Old Sep 20, 2006 | 04:33 PM
techbod's Avatar
fuel pump is in the tank so no noise should be heard but the fuel filter is near the tank underside of the car and it might be vibrating on the chassis
Old Sep 20, 2006 | 04:35 PM
ok i'll have to check it out then.. thanks
Old Sep 20, 2006 | 10:04 PM
Adam@mvp's Avatar
Go get a Walbro GSS 340 it will work great
Old Sep 21, 2006 | 01:55 AM
a4sport's Avatar
Good think I had this same problem. It's your fuel filter. If you bend down and look at the filter when it's making that noise, you'll be able to tell it's that. Just a clogged up filter. Easy to replace. PM me if you need help. I did a write up on install. Also, check to see if your fuel pump is covered under the recall. That's not what's making the noise, but still nice to have a new fuel pump for free if you fall under the recall.
sunilmsahoo
Mar 3, 2015 01:59 PM
audiaxel
Jan 21, 2014 06:45 PM
black19
Apr 6, 2009 01:11 AM
hesserjw
Jan 16, 2008 09:25 PM
Audi_A6_BayArea
Oct 14, 2007 03:52 PM
