possible problem
Old Jan 11, 2006 | 09:51 PM
ShaodwMav's Avatar
Default possible problem
a few days ago when i was changing my oil instead of crawling under my car and finegaling my arm around to get to the oil filter i took the intake hose off.......and what was that i saw and smelled.......it was burnt oil.....so i took off the hose on the bottom of the inter cooler to see if there was alot of oil in the intake system.....there wan't just a thin layer of oil....so my question is is my turbo's bearing gone/going bad???? and if so when i replace it can i throw on the k04 and add the other stuff later?????¿¿¿¿¿¿¿¿¿¿¿¿
Old Jan 12, 2006 | 01:08 AM
AudiTech04's Avatar
Default RE: possible problem
It is normal for there to be oil in there
But the question is how much is a lot??
I would say anything over 1/4 quart is too much
Old Jan 12, 2006 | 09:30 AM
ShaodwMav's Avatar
no not a 1/4 quart just a thin layer on all the intake tubing from turbo up......but still can i run the k04 on stock everything for a few months????
Old Jan 12, 2006 | 10:07 AM
dafrazi's Avatar
Yes you can run the K04 with stock parts.
Old Jan 12, 2006 | 02:46 PM
clconversion's Avatar
I would take your intercooler out and clean that also
Old Jan 12, 2006 | 05:51 PM
ShaodwMav's Avatar
is there any write ups on here i haven't seen any......and what should i clean it with????[sm=helpout.gif]
Old Jan 15, 2006 | 12:16 AM
ShaodwMav's Avatar
bump... anything guys???
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
