power steering chirp only on one side
Old Jan 21, 2008 | 01:07 PM
tculber's Avatar
Default power steering chirp only on one side
I searched it but couldnt find anything. I figure its the pump or belt but i have a leak but it chirps when the fluids full. The steering only makes sounds when i turn to the left but not to the right. Does anyone have any ideas?
Old Jan 21, 2008 | 01:18 PM
CRAZYHAWK's Avatar
Default RE: power steering chirp only on one side
Find the leak, and let's hope it's not the steering rack.
Old Jan 21, 2008 | 09:26 PM
tculber's Avatar
its just inside the right wheel
Old Jan 22, 2008 | 05:38 PM
tculber's Avatar
anybody have any experience with something like this
Old Jan 22, 2008 | 08:08 PM
dankhound's Avatar
Make sure the rack isnt rubbing on the body. If that isnt happening you probably have a binding tie rod or ball joint. You can feel the arms while turning the wheel making the noise. The one that vibrates the most is probably the culprit.
Old Jan 22, 2008 | 08:12 PM
ThreePointOhhh's Avatar
if this happens while you're turning in motion, could be your cv joint. check the boots and make sure they're not ripped. If this is at a standstill then... its properly a leak.
Old Jan 24, 2008 | 09:12 AM
CRAZYHAWK's Avatar
He said there is a leak.
SUPERMARIO680
Jul 13, 2012 01:33 AM
cmacelo121
Aug 21, 2009 05:59 PM
Leeer73
Oct 5, 2008 02:51 PM
