Pray for Arif..
Old Feb 21, 2006 | 01:42 PM
  #571
Emil@RENN=ART's Avatar
Default RE: Pray for Arif..
from your description of how it happened, it sounds like something got loose somewhere... you might have gone over 25psi too.. it's hard to spot sometimes on a gauge how high you really spiked.. check all hose connections and definitely that big hole in the fmic. also check the wastegate (for example, it could be partially stuck open.. hence not building boost). this would obviously also make you very rich.
the mbc might now be flashy.. but it's AMS' MBC that we include in the package.. it's very very solid! it's works as good as a MBC can work. unless, of course, you don't think (our neighbors btw) AMS does quality parts and work. www.automotosports.com
Old Feb 21, 2006 | 01:57 PM
  #572
aRIf's Avatar
I'll take a look at that hole, I hope it is my problem. so Do I need to welding a metal piece over there ?
Renn-Art;
It is almost impossible to access to wg, I check it yesterday but I dont know.
Old Feb 21, 2006 | 01:58 PM
  #573
kakarot's Avatar
Arif, did you try to close the wastegate, disconect it at all. and check if the car builds the boost.
CAREFULL not to overboost.
If you disconect it and check it if no boost is builded then you have a huge leak.
Old Feb 21, 2006 | 01:59 PM
  #574
goldenchild's Avatar
if that looks like quality maybe i should sell my **** as a rembrant.....and it wouldnt make it run rich at idle bc there is no boost. if the wastegate arm is stuck on something causing to stay open yet another flaw in the kit. im just going to put the money on the freakin hole left in the i/c
Old Feb 21, 2006 | 02:09 PM
  #575
kakarot's Avatar
and, if car runs rich, it the ECU stile car, if all the sensors are okey, then the only ECU controles the AF mix.
I would check the O2 sensor, then Turn the boost UP NOT DOWN. You saying that the car runs reach then All you need is more air.
Move wastegage pulley to check if the valve moves. Disconect all the electrical controles over the boost. And try to run boost.
Old Feb 21, 2006 | 02:34 PM
  #576
onepoint8tee's Avatar
ORIGINAL: aRIf
I hope thats not your problem if it could have sucked some duct tape into your engine.
Old Feb 21, 2006 | 02:55 PM
  #577
if he did that he wouldnt have an engine right now. when tom melted his spark plug his engine blew instantly
Old Feb 21, 2006 | 02:58 PM
  #578
aRIf's Avatar
I'm going to check it now, I'll let you guys know.
Old Feb 21, 2006 | 03:40 PM
  #579
ORIGINAL: goldenchild
i guess it doesn't look like much... but who cares when you do work on evos that produce 903awhp (all boost).
quality is not always the prettiest.
true.. that's what i'd say too.. but again, just a guess, since i'm not there.
also remember that the ndbw's are a lot more sensitive to tiny leaks, mainly since they don't have that boost sensor..
Old Feb 21, 2006 | 04:47 PM
  #580
just a question if someone is makin 900 awhp why the hell r they runin a mbc?
