problem
Old Oct 2, 2006 | 03:41 PM
brownboy1690's Avatar
Default problem
my abs and brake sign keep popping up indicating that my abs is not working. i was wondering if this happens to anyone else? do you guys think it's just an electrical thing?
Old Oct 2, 2006 | 04:12 PM
CRAZYHAWK's Avatar
Default RE: problem
Last summer 2005, I had the same problem. It was caused by dirt on a wheel sensor.
I tapped each brake caliper with a one pound hammer. This link may help you determine
which sensor is at fault:
https://www.audiforums.com/m_99381/tm.htm
Old Oct 2, 2006 | 04:42 PM
socal_A4's Avatar
Default RE: problem
ORIGINAL: CRAZYHAWK
yea the sensor is dirty and unable to give a good connection/ reading... If what he said doesnt work then ther is a thread on audiworld that tells you how to do it step by step... you have to take off the wheel unplug the sensor clean it out... Remember when your connecting everything back together dont plug the sensor all the way back in... Ask chrisspay for more details, it happend to his car...
Old Oct 2, 2006 | 07:13 PM
wood_e's Avatar
Default RE: problem
Not so fast there guys.... Get a VAG and see if you can communicate with the ABS computer, if not then your ABS computer needs a rebuild ($250), if so try cleaning your ABS sensors... I just found out that the tone ring on my driver rear (which was causing my ABS to malfunction) had a chip out of it due to corrosion, so I need a new outer CV joint...
Old Oct 2, 2006 | 07:16 PM
Default RE: problem
thanks for all your advice, but i took my car to the mechanic today and he says the sign just pops up when you press the brakes too hard. he said if the sign stays up then there's a problem
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
