Problem in displaying radio info on dashboard
Old Aug 7, 2004 | 09:53 PM
Dr_Vitez's Avatar
Default Problem in displaying radio info on dashboard
I buy A4 1998 with trip computer but in car wasnt radio.
I found power and wofer conectror but didnt find system conector
there is pinout with pins: CLK, DATA, ENA.
Must find way to conect these pins to dash becaouse every audi which have trip computer have posibility for conecting radio to dash.
please help
Thanx in advance
Old Aug 8, 2004 | 12:13 AM
Jestnomen's Avatar
6th Gear
Default RE: Problem in displaying radio info on dashboard
Um, i'm having trouble figuring out exactly what you mean by all that. Do you mean you have an A4 with an aftermarket radio that you want the trip display to display the radio station?
Old Aug 8, 2004 | 01:33 AM
Doose's Avatar
Well, if you mean connecting your factory system back up to make the cluster radio display work that's doable. But if you mean making it work with an aftermarket head unit, I am not aware of a way to do that. Give us an exact description including what deck you have, what year, and what exactly has been done to the system. Welcome to the forums. I hope we can help you out with this.
Old Aug 8, 2004 | 07:38 AM
Dr_Vitez's Avatar
Im my problem are things:
Buy used A4 1997.12 car without radio.
Found in hole for radio: main power euro jack, speakers euro jack, and other conector which i dont know for what is.
This third conector is in complete with main power cables.
Speakers cable is for 4 speaker and cables are new (think home made).
So i dont want aftermarket radio, i want Audi radio.
Problem is that if third conector isnt for dach conection.....what then.
Have trip computer so have option for displaying radio data on dash.
So if third conector isnt for dash, how to locate main cable from dash ( i think there areATA, ENU ...)
Want back to original audi sound.
And read if i get simphony2 that will have problems becaouse simphony 2 have some CANBUS.....
Thanx for helping.
[IMG]local://upfiles/2212/14151E410CF647F4BFD8CC45B507996A.jpg[/IMG]
Old Aug 9, 2004 | 09:45 AM
Jestnomen's Avatar
6th Gear
You will run into some problems installing a Concert II radio into your car. It will shut off every hour on its own, and there will be no backlight for nighttime. You can fix the night backlight problem though.
http://www.audiworld.com/tech/elec86.shtml
Old Aug 9, 2004 | 09:59 AM
Jestnomen's Avatar
6th Gear
almost forgot this...
This will tell you what every pin on the connectors do.
Old Aug 9, 2004 | 07:21 PM
Dr_Vitez's Avatar
Big thanx Jestnomen
for so much info for radio pinout.
if im right then i must get 3 wires from radio to dash.
This are pins:
8 Clock signal
9 Data signal
10 Enable signal.
And for last question is....
WHERE TO PUT THIS TREE WIRES (8,9,10) ON DASH SO RDS AND REST INFO FROM RADIO GO TO DASH.
And what about thisr conector i send to forum ( SEE ATTACHMENT) https://www.audiforums.com/upfiles/2...45B507996A.jpg
Thanx in advance.
myrcen
Jul 7, 2013 12:18 PM
Domingo
Apr 27, 2011 04:09 PM
Abe Froman
B7 Models
Nov 7, 2009 08:22 PM
hahaha251251
Nov 15, 2008 11:15 PM
jjuzwik
Nov 16, 2007 06:37 PM
