PROBLEMS....
Old Jul 23, 2006 | 03:21 AM
BaconBait's Avatar
Default RE: PROBLEMS....
Check out the perormance sites on the Audi Links page. You can get better quality from a reputable source for less.
Old Jul 23, 2006 | 05:01 AM
PJTocci's Avatar
ORIGINAL: RLB6
It's purpose is to purge boost coming from your turbo when you're not on the gas. Basically, when you shift or deccelerate, you're off the gas, therefore closing the throttle. if you're under boost at the time, the boost pressure traveling form the turbo to the intake has no where to go, but back down to the turbo, causing a surge which would eventually damage the turbo. the diverter valve does exactly as it's name, it diverts the boost pressure away and recirculates it back into the intake before the turbo.
So, now that we got that down, the dv has a nasty tendency to fail because its a plastic unit with a rubber diaphram. When this dv starts to fail, it starts leaking boost back into the intake, even on acceleration, which causes the engine not only to lose power, but cause slight bucking if the valve is intermittently failing. So, replace the valve and see if that fixes the problem, if not, then you'll have to look into other components that maybe failing, like the N75 valve, coil, plugs, etc..
BTW, the valve is like $35( I think ) for a stock unit. I suggest you purchase a dv for an audi TT, this one is refered to as the 710n valve or you can get a nice aftermarket unit from forge or hyperboost which runs up in the mid to high $100s.
Does this answer your question?
i think we have a new sticky [sm=icon_rock.gif]
Old Jul 23, 2006 | 10:53 AM
david9999's Avatar
Even though the check engine light isn't on, have the engine checked for codes and report them back. Autozone will pull the codes for free.
Old Jul 23, 2006 | 11:24 AM
JettaRedII's Avatar
ORIGINAL: david9999
Exactly! The Check Engine Light (referred to as "CEL" and can more accurately be called the "MIL" for "malflunction indicator light") does not come on immediately when an emissions problem occurs. The "problem" must occur more than once, but can seem to happen immediately. Have the ECU scanned for codes. However, generic OBD readers, like at AutoZone, will only give the code; you need to then look up its description. If the code is manufacturer specific, you'll need a Bentley manual or to post your codes here or on the VAG-COM forum at http://groups.yahoo.com/group/VAG-COM
Old Jul 24, 2006 | 01:22 PM
patty AT forge's Avatar
ORIGINAL: thepirate
ORIGINAL: RLB6
what about this valve i found on ebay?
http://cgi.ebay.com/ebaymotors/AUDI-...QQcmdZViewItem
worth the purchase or not worth the purchase?
Looks to be a knock-off of our 007 DV.
Old Jul 25, 2006 | 12:37 PM
kaklexicon's Avatar
PJTocci, your pic is hilarious. HAHAHAHA.
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
