Problems after doing timing belt.
Old May 14, 2005 | 06:21 PM
99AudiA4q's Avatar
Default Problems after doing timing belt.
I went and took my car to get the timing belt changed guy charbged me $700 to do it. A day after i start noticng that the temperature sometimes doesnt reach the middle stays down a little. And after letting the car idle for about 5 months standing still i get in and notice my temperature is completely cold this is 5 before getting off a highway and running the car for about 20 minutes on the highway. I take it and he "rebleeds" the system a day after the same problem what could it be? I asked him and he never changed the Thermostat what do you guys htink it could be?
Old May 14, 2005 | 06:26 PM
mainer's Avatar
Default RE: Problems after doing timing belt.
did the guy take the thermostat out and not put it back in?? thats about the only thing i could think of that would cause that problem..
that or the wiring for the temp sensor is loose?
Old May 14, 2005 | 07:44 PM
headshok2002's Avatar
def sounds like thermostat to me. maybe he put in a cheap failsafe one, and its already screwed itself and stuck open.
In my talon I went through 4 thermostats in 2 weeks before I went with OEM (kept getting them replaced over the counter, under warranty).
Old May 14, 2005 | 10:20 PM
Shaunp05's Avatar
He should have changed tha Stat in the first place, but it looks like that is the prob
Make sure you getting good heat that is a sign you have good circulation of coolant
if not take it back ASAP
Old May 14, 2005 | 10:54 PM
TomRitt's Avatar
either thermostat or coolant temp sensor
Old May 15, 2005 | 03:06 PM
jlaudio184's Avatar
sounds like a coolant temp sensor, same problem happened with mine then i got the timing belt done and they spotted it at the VW dealer and changed it.. part is only like 20 bucks
Old May 16, 2005 | 06:02 PM
insuite's Avatar
If it only cost $700 he didn't replace the water pump or thermostat. The parts alone are over $300. So I'd go after the coolant temp sensor like jlaudio184 said.
Old May 16, 2005 | 06:05 PM
BFlan2001's Avatar
if you scan it with a vag-com it will tell you if your coolant temp sensor is failing. they're fairly easy to replace, and they're 8 bucks i believe at ecstuning.com, or 25-30 at the dealership. the thermostat is not as easy to replace, and also more expensive, so i'd go for the temp sensor first..
planedr65
Aug 5, 2012 09:39 AM
aks72
Jun 13, 2011 07:39 AM
laser
Nov 14, 2009 03:16 PM
heyarn1
Sep 17, 2007 09:43 PM
Seagull16
Oct 29, 2006 06:14 PM
