A6 2.8 12 v, timing belt problems.
Old Sep 17, 2007 | 09:40 PM
heyarn1's Avatar
Default A6 2.8 12 v, timing belt problems.
i run a small general repair shop in mass, i have never woked on a a6, it is a quattro, with 115k, the timming belt seems to have jumped after the car was started after it sat unused for a week or so, i t appears to have valve problems, i get no compression at #1 with the valves closed, so my question is what kinda job am i getting into, i have done many, many top end jobs, also should i maybe consider replacing the eng?
Old Sep 17, 2007 | 09:43 PM
auditech79's Avatar
Default RE: A6 2.8 12 v, timing belt problems.
You need to pull both cylinder heads and have another shop do the valve work, un-less you have the special tools to overhaul the head, its a pain in the ***.
You shouldn't need a new engine, usually the pistons get a small knick but they should be fine.
planedr65
Aug 5, 2012 09:39 AM
aks72
Jun 13, 2011 07:39 AM
laser
Nov 14, 2009 03:16 PM
Seagull16
Oct 29, 2006 06:14 PM
99AudiA4q
May 16, 2005 06:05 PM
