problems using an obdII ?
Hi
I'm having problems using the obdII to read my computer on my 2002 a4 1.8t,, does anyone have expirienced the same problem? or how did you make work,,? ( dos it have to be in a certain mode , like neutral or something like that?
thanks in advance
thanks in advance
If by chance you are using a serial to USB adapter for it, you need to setup the COMM ports in your device settings in windows so that its set up on the same port as what VAG COM has it as. The first 2 or 3 comms are usually taken, I selected port 4 in my device settings in windows, and then selected port 4 in vag com. Other than that, it should work ok.
I think he is talking about the 3100 model OBD2 and not VAGCOM. Are you getting ERR on the screen of the meter? I think the OBD2 does not work on Audi, you need the VAGCOM. I got the same error when I tried my friends' meter.
