Quattro 2.5tdi
Old Mar 1, 2006 | 02:23 PM
spud561's Avatar
Default Quattro 2.5tdi
Hello all I wonder if I could ask for some help.I am trying to restore my 2.5 tdi and I have the following problems.
1 under light breaking and at slow speed the front right abs seems to cut in I have no abs light and the breaking at a higher speed or more break pedal the abs does not cut in. The car has a new abs sensor on the front right and I am hopeing that it has not been set up right I have removed it and cleaned the abs ring but cannot find and info on the distance it should be from the ring?
2. Does a 1999 quattro have remote central locking as standard as when I bought the car it had no key fob only standard keys?
Thanks in advance for any advise
Regards James
Old Mar 1, 2006 | 03:17 PM
techbod's Avatar
Default RE: Quattro 2.5tdi
1. does the abs light come on for 4 seconds when you turn the ignition on if not the bulb has been removed to help sell the car a common trick,
2. depends on how old the car is
hybstheory
Oct 17, 2012 01:24 PM
fra
Oct 11, 2011 11:36 AM
blanc
Sep 19, 2011 06:18 AM
diarmuid
Nov 25, 2005 05:30 AM
nasti
Oct 9, 2005 07:59 AM
