Sponsored by:
Sponsored by:
Quattro to FWD just to Dyno???
Old 02-26-2007, 09:33 PM
Audi_Skydiver's Avatar
Default Quattro to FWD just to Dyno???
Ok,
I am wanting to dyno my car, however the closest AWD dyno center is about 5hrs away. I have heard that you can disable either the front or rear wheels for a short amount of time. Has anyone done this or know how to do it? Like I said, it is only to Dyno the car. Not drive around for a long time. Thanks.
Josh
Old 02-26-2007, 09:47 PM
Default RE: Quattro to FWD just to Dyno???
Anyone? PLEASE????
Josh
Old 02-26-2007, 09:54 PM
tractioncontrol's Avatar
The dyno shop can do it for you and usually at no extra cost.
Old 02-26-2007, 09:57 PM
I just called them and they have never done that before. Any other ideas?
Josh
Old 02-26-2007, 10:11 PM
Bondga's Avatar
i dont think disableing the rear wheels would be effective. most likely all they will to is remove the axles and the drive shaft will still be spinning.if so your dino wont be accurate because some of the power will still go through the rear drive shaft
Old 02-26-2007, 10:15 PM
onepoint8tee's Avatar
ya your dyno wont be accurate if you do what you are trying to do. Your center diff and mid/rear axles eat up a bit of your whp which wouldnt be represented in the dyno results if you disable those things.. Why do you want to dyno it anyway? What mods do you have?
Old 02-26-2007, 10:39 PM
leighsean's Avatar
im in spokane, where is this dyno your talking about? seattle? or portland?
Old 02-26-2007, 10:52 PM
To answer the question about why I want to dyno it. The InMotion Tuning company is giving me a free tune if I will run a before and after dyno so they can use it as advertising! And the dyno is the Shellys Performace Dyno Center. Look it up on yellow pages. It's in Spokane.
Josh
Old 02-26-2007, 11:12 PM
leighsean's Avatar
you still havent mentioned what you drive...
Old 02-26-2007, 11:16 PM
A 1999 Audi A4. 1.8T.
Josh
Quick Reply: Quattro to FWD just to Dyno???
