Oxygen Sensor Bank 2 on a 1.8T? MIL ON
Old Jul 22, 2010 | 12:48 PM
reject902's Avatar
Exclamation Oxygen Sensor Bank 2 on a 1.8T? MIL ON
Hey guys, I know this is my first post and all, so please don't attack me cause I'm a total newb. I have been lurking in the shadows for awhile quietly, I just never had much to contribute.
Anyways, here's a short run down of what's been going on. I have a 2002 A4 1.8L Quattro @ 182k that I've been the owner of for 5 years. My car lost most of it's acceleration and thew the MIL light a month or so back. Took the car to the stealer, and they suggested new cat and crankcase hoses, as the codes wouldn't stay cleared and they could see it really lost its power. Had the cat, hoses and check valves replaced (not at the dealer, but an indy shop) and drove fine for a few days. MIL light came back on and I ran the codes with VCDS again. Same codes came back again after maybe 20 miles. These codes are the same that I pulled when I took my car to the dealer the first time.
I initially thought maybe I needed a new pre-cat o2 sensor. The only thing is, the code thrown shows as Bank 2, Sensor 1? There's so much reading I've done on here and my mind is maybe a mess right now, but isn't it that my car only has a Bank 1? Would I be looking at a bad ECU then?
Any suggestions are greatly appreciated.
Thanks,
Code:
Control Module Part Number: 8E0 909 518 F
  Component and/or Version: 1.8L R4/5VT     G   0001
           Software Coding: 0016751
            Work Shop Code: WSC 63351
2 Faults Found:
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
        P0420 - 002 - Lower Limit Exceeded
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
        P1131 - 001 - Upper Limit Exceeded
Old Jul 22, 2010 | 09:43 PM
reject902's Avatar
Oh, and I wanted to add too that when using a generic hand OBD-II scanner there's a change in codes. I still get the cat threshold code in generic form, but I also get a "system too lean" code, which isn't present in VCDS. The hand code scanner as you can see is also missing the o2 sensor code.
Code:
P0171: Fuel Trim; Bank 1: System Too Lean
P0420: Catalyst System; Bank 1: Efficiency Below Threshold
And on another odd note, I pulled the saved codes I had from a scan on June 9th, and there was another odd code in VCDS that was thrown that also wasn't on my hand code scanner at the time and shouldn't apply to my car.
Code:
17970 - Quantity Adjuster (N146): Upper Limit Reached
        P1562 - 002 - Lower Limit Exceeded
After that clear I never saw it again..
I don't know what I'm dealing with here. Bad ECU? VCDS not working correctly? Any ideas?
Thanks,
Old Jul 23, 2010 | 12:34 PM
pa4ul's Avatar
I always thought one closer the the front and one farther in the back. And one of them is a real pain to change.
Old Jul 24, 2010 | 11:35 PM
reject902's Avatar
Well I know theres a front sensor, sensor 1 precat and rear sensor, sensor 2 postcat.. But on my car I should only have a bank 1 right? This is claiming the fault is at bank 2..
lespaul2510
Jul 6, 2019 02:48 PM
mtrainum
Dec 24, 2011 07:32 PM
spiney
Jul 15, 2009 10:18 AM
brent07
Jan 19, 2007 03:57 PM
NoFlyZone
Jul 14, 2005 11:32 AM
