quick DV question
Old Apr 6, 2007 | 11:20 PM
mikejda's Avatar
Default quick DV question
ok please don't burn me on this. I just got in the Forge007 dv for my 1.8t, 2001, my question is that the DV came with 2 springs and 2 flat metal pieces what do I do with these?
thanks remember I'm a newbie
Old Apr 6, 2007 | 11:22 PM
cincyTT's Avatar
I'm make believe
Default RE: quick DV question
depends on your level of psi. stick with whats inside for stock and change to yellow for a chipped car.
Old Apr 6, 2007 | 11:31 PM
mikejda's Avatar
dude at first i had no idea what you were talking about, than i realized it unscrews. So I do plan on chipping it soon with GIAC, so your saying I should take the green spring out of the inside and put the yellow spring not the blue.
Old Apr 6, 2007 | 11:32 PM
mikejda's Avatar
another question whats the 2 flat metal pieces for?
Old Apr 6, 2007 | 11:35 PM
cincyTT's Avatar
I'm make believe
they are shims to add a little more stiffness without changing springs. if you have a little flutter it would work better than adding a higher rate spring.
Old Apr 6, 2007 | 11:38 PM
mikejda's Avatar
\do the 2 metal pieces go on the inside. One on each side of the spring
Old Apr 6, 2007 | 11:39 PM
mikejda's Avatar
ok cool thanks alot. So go with the yellow not blue than?
Old Apr 6, 2007 | 11:42 PM
cincyTT's Avatar
I'm make believe
you should be ok with the yellow
Old Apr 7, 2007 | 12:06 AM
mikejda's Avatar
thanks again. I love this site
jmcdowel
B7 Models
Jan 6, 2014 05:48 PM
grimace132
Nov 21, 2012 08:10 PM
DustanS
Jun 10, 2011 10:45 PM
khj677turbo
Dec 23, 2007 06:00 PM
ThePapaCMan
Apr 11, 2007 02:26 AM
