quick question! my oil light flashed and beeped at me!
Be careful. If the oil light comes on again solid you can slowly make it home. Solid light on the audi means low oil pressure. Flashing oil pressure light means 0 pressure. Shut the car down immediately. Either way, I'd drive the car as little as possible until this is sorted out. Otherwise this could turn into a 3000 dollar bill for rebuilding the engine.
i had the exact same problem two days ago, i checked the oil level, and it was ok. The light didnt turn on again, but i´m scared has hell, let me know what was your problem.
Mine beeped like that after I turned the car off, but only when my ABS controller was bad, after that was fixed I never saw the light again, so I figured it was all an electrical issue
I also get the light to come on every so often, mostly as I make a shart right turn. Another sympton I have is my engine will tick loudly when I drive the car hard or drive it on the freeway for a long period of time. I figure that my oil pickup tube is clogged. I plan to open my valve cover and drop the oil pan to see what kind of oil sludge I have. I have previously tried using seafoam, didnt seem to help too much.
Mossyoakglock
Dec 28, 2010 01:13 PM
