Quick question regarding stereo codes...
Old Dec 21, 2006 | 04:18 AM
ImTheDevil's Avatar
Default Quick question regarding stereo codes...
OK, I know most people have talked about how the A4 head unit needs to have its operational code re-entered after disconnecting the battery or it won't work. Several posts that I read regarding this were in reference to the Symphony or Symphony II systems. My car has the Audi Concert system - does this system also require a code after the battery is reconnected? The guy I got the car from had all his work done at shops, so if it was required, they'd have re-entered it - he didn't know offhand if the car needed it. I'm going to be putting my amp and sub in shortly and want to know in advance if I'm gonna have to remove it to see if the code is labeled on the deck as some people have said. Any takers on this one - does the Concert system require a reactivation code?
TIA...
Old Dec 21, 2006 | 04:38 AM
AWDaholic's Avatar
Senior Administrator
Default RE: Quick question regarding stereo codes...
I can't answer the question, but, I can offer a suggestion that a quick call to the Stealership, if no one here has an answer, should provide the info you need.
Old Dec 21, 2006 | 04:49 AM
theguy1084's Avatar
So is it the "stealership" or is it the place where you pay people for @#!$ you dont know...................hmmmmm
Old Dec 23, 2006 | 11:56 AM
dankhound's Avatar
Most likely it will require a code. Sometimes for whatever reason they dont, but most concerts require a code.
Old Dec 23, 2006 | 06:32 PM
kokar's Avatar
Yes I thinks so its most likely it will require a code.Just contact the one u bought the car from to send u the code. Good Luck to my friend!
regards
kokar
Old Dec 23, 2006 | 06:49 PM
ultrasport's Avatar
i got the audi symphony bose sytem and i dissconnected my battery several times and never needed no code
Old Dec 23, 2006 | 08:20 PM
01A4T's Avatar
Yes, you will need a code. if you got a manual and other material when you bought the car, then you should hopefully find a small card that has the code on it. it could also be attached to the sound system/radio manual.......
Old Dec 25, 2006 | 12:24 AM
dankhound's Avatar
Newer cars dont always require a code.
Ryanic
Jun 9, 2013 11:57 PM
inetforce
Mar 8, 2009 06:24 PM
fenderstrat1184
Jun 23, 2007 05:06 PM
ImTheDevil
Apr 16, 2007 11:09 AM
metalks
Mar 17, 2006 08:31 AM
