quick tech question
Hey i just had the motor for the door locks replaced in my a4 as it broke. The guy that did the work didn't have both keys so he said he wasn't able to "sync" the keys to the motor or whatever for the keyless entry to work.
Anyone know how to get this to work again? i know there is a process w/ one key in the ignition and i am not sure about the other key. thanks in advance.
The following instructions are to reprogram your switchblade key fob.
1. Take a spare key and insert it into the ignition. Turn it one click forward.
2. Roll down your window just in case. Step outside the car, and lock the car with a second key.
3. With your second key fob press the unlock button. The lights should flash.
4. Now lock the car with the key fob, and then unlock it.
5. Remove the key from the lock and the key from the ignition, and try it's function
it worked perfectly!
