quick tech question
Old Jul 10, 2007 | 04:39 PM
swift_A4's Avatar
Default quick tech question
Hey i just had the motor for the door locks replaced in my a4 as it broke. The guy that did the work didn't have both keys so he said he wasn't able to "sync" the keys to the motor or whatever for the keyless entry to work.
Anyone know how to get this to work again? i know there is a process w/ one key in the ignition and i am not sure about the other key. thanks in advance.
Old Jul 10, 2007 | 05:04 PM
swift_A4's Avatar
Default RE: quick tech question
bump
Old Jul 10, 2007 | 05:07 PM
badboi24u's Avatar
i think there is a diy on how to get the keys to work. iv seen it before but i just dont remember so do a little search.
Old Jul 10, 2007 | 06:03 PM
CRAZYHAWK's Avatar
The following instructions are to reprogram your switchblade key fob.
1. Take a spare key and insert it into the ignition. Turn it one click forward.
2. Roll down your window just in case. Step outside the car, and lock the car with a second key.
3. With your second key fob press the unlock button. The lights should flash.
4. Now lock the car with the key fob, and then unlock it.
5. Remove the key from the lock and the key from the ignition, and try it's function
Old Jul 10, 2007 | 06:09 PM
swift_A4's Avatar
Thanks i will try that out tonight
Old Jul 10, 2007 | 06:18 PM
CRAZYHAWK's Avatar
Good luck.
Old Jul 11, 2007 | 02:21 PM
swift_A4's Avatar
thanks for the info it worked perfectly!
tambleramble
Mar 23, 2009 06:51 AM
pimphell
May 31, 2008 03:47 AM
joelml
Sep 18, 2007 06:16 PM
Soley4pres
Jan 5, 2007 10:28 PM
Devilish
Dec 2, 2006 12:39 AM
