Radiator Coolant question
Old Jan 22, 2007 | 10:23 PM
southcoast's Avatar
Default Radiator Coolant question
Pep Boys says i can use the orange coolant they have for i believe GM, is that OK?
Old Jan 22, 2007 | 10:24 PM
2k S4's Avatar
Default RE: Radiator Coolant question
NO, it may cause the system to turn to gel.
It's not worth it to save $10.
Old Jan 22, 2007 | 10:27 PM
southcoast's Avatar
What do you recomend? would the regular green coolant do it or is there anything i can get at a local auto parts store?
Old Jan 22, 2007 | 10:39 PM
onepoint8tee's Avatar
Pentosin G12
Get it from one of our sponsors or the dealer. Its not found at pep boys or any other local store unless you have a euro tuning shop close by maybe.
Old Jan 22, 2007 | 10:43 PM
southcoast's Avatar
Thanks man, i will do some searching on that
Old Jan 22, 2007 | 10:53 PM
2k S4's Avatar
Yes, either Petosin, VW, Audi & Porsche all use it.
It HAS, HAS to be G12, or G12+
All else will be BAD. You only need one gallon, and then at least 2 g of Distilled water.
Old Jan 22, 2007 | 10:58 PM
southcoast's Avatar
I just called my dad,he works for Mercedez-Benz and hes going to ask the parts dept. if they carry it, if they do ill pick some up after work, its about 7 blocks away.
Old Jan 22, 2007 | 11:12 PM
2k S4's Avatar
ORIGINAL: southcoast
I just called my dad, he works for Mercedez-Benz and hes going to ask the parts dept. if they carry it, if they do ill pick some up after work, its about 7 blocks away.
MB doesn't use G12.
It's orange, & they have like 4 types.
http://www.mbca.org/pages/tech/MBCA_Antifreeze.htm
Why are you fighting the system so bad here?
YOU NEED G12, GO BUY G12, NOTHING ELSE!
MirzaRamovicPNW
Sep 3, 2012 12:55 AM
sivak.puvvula
Dec 27, 2010 11:22 AM
imrankz
May 20, 2010 04:57 AM
tmatiacio
Aug 13, 2009 01:15 PM
shady927
Apr 11, 2008 06:46 AM
