Radio Lockup! And Squeak!??? HELP!
Old Feb 25, 2006 | 10:36 PM
Karl's Avatar
Default RE: Radio Lockup!
yes, that could be a possibility, but it could be that there for some reason is no power running to the radio, that could also be the reason.. On my radio (for the brief time i had it in) it would say "LOCK" until i held the FM1/2 and RDS buttons then it would allow me to input the numbers by tapping 1 the value of the first digit.. ie first digit is 4 tap 1 four times.. at no time did my display ever go out.. if you look on the display look to see if you have a little mark in the lower right hand corner, on the plastic of the radio it will say CODE i believe.. and if there is two marks there that means you are locked out for the hour, because you have tried twice..
Old Feb 25, 2006 | 11:17 PM
Russ03A4's Avatar
Take it to an Audi dealer. Be a nice guy and they just might help you out for nothing. My dealer helps me with a lot of little stuff for no charge.
Old Feb 25, 2006 | 11:33 PM
avanttripleloop's Avatar
much apologies redgoat.i was wrong.screen not supposed to be empty but safe i guess.i found paperwork dealership gave me when they were looking to get mine on.since i'm a computer lame,i cant do a quicklink,heres the page though; www.ibiblio.org/tkan/audi/radios/concert.html
Old Feb 26, 2006 | 01:05 AM
sandman's Avatar
squeaky control arms are a common problem. 700 is high but what else can you expect from the dealer.
Old Feb 26, 2006 | 02:15 AM
Karl's Avatar
hahaha.. that was what i was looking for "Safe"!
Old Feb 26, 2006 | 10:36 AM
david9999's Avatar
Does your radio work?
Is the radio on?
For the front squeek, it is control arms. Not an Immediate fix.
Shop around for a good shop. I picked up the two upper arms I needed for about 120 dollars. Replacement was another 75 dollars.
Old Feb 28, 2006 | 09:39 PM
deutscheCrazy!'s Avatar
Hey Redgoat, i see in the lower right hand corner under the actual screen red letters that say CODE but i dont see what your talking about with the marks???
Old Mar 1, 2006 | 12:17 AM
  #18
Karl's Avatar
if your display is working, and you enter the incorect code, you get 1 little mark there on the screen, do it again to the point where it locks you out, the second mark lights up
Andretti
Jun 28, 2011 05:48 PM
histeel
Sep 1, 2010 06:30 PM
ron86toy
Jun 4, 2009 05:14 PM
marcb0127t
Feb 7, 2009 07:55 PM
Perfecto951
Sep 5, 2005 11:46 PM
