Torque converter lockup solenoid location
Old Aug 30, 2010 | 11:03 PM
histeel's Avatar
Default Torque converter lockup solenoid location
I have ran a scan with the vagcom and got the po741 code for the first time on a 2000 a6 Transmission shifts well and have not had any problems with it except for the cel i just scanned. I am going to change the fluid and filter this weekend and change the tcc solenoid but i cant find any info on which solenoid is the tcc lockup. Thanks for any info on which solenoid to pull.
Old Aug 31, 2010 | 01:30 PM
broken98c5's Avatar
here check out this link it helped me out im having the same prob on my 03.
ill let you know the outcome when it gets compleated.
http://forums.vwvortex.com/showthread.php?4678124
Old Sep 1, 2010 | 02:26 PM
nemohm's Avatar
The original TSB:
Subject:
Model(s):
Group:
Number:
Date:
MIL Illuminated, DTC 17125 Stored in Transmission
Fault Memory – No Driveability Concern
2001  2004 to
VIN 4B_4N024000
32
05–02
A6, allroad w/ 2.7T (Eng code Oct. 25, 2005
APB, BEL & Automatic Trans
Evidently even the repetitive failures did not stop Audi to sell defect transmissions.
Old Sep 1, 2010 | 06:30 PM
histeel's Avatar
From i have determined there are several things that will cause this code, so i think i will change fluid and filter, inspect and clean The two solenoids resposible for the torque converter lock up.The mechanic has told me he has had some sucess with using redline fluid change and inspecting the wiring and solenoids. If this doesnt work the neigbors had better keep the kids inside for the next week or there liable to here some words they have never heard before.
survtime
Apr 15, 2012 06:04 PM
pookyjason
Aug 15, 2011 08:07 AM
SkipsA6
Mar 15, 2011 01:07 PM
aron56
May 26, 2010 11:39 PM
Avant13
Apr 14, 2008 09:19 PM
