Random Misfires question
Old Dec 29, 2007 | 02:48 PM
cincyTT's Avatar
I'm make believe
Default RE: Random Misfires question
In not sure and dont want to give you bad info, so im going to let auditech79 chime in on that one
Old Dec 29, 2007 | 05:56 PM
rbflip's Avatar
I am trying one more thing before I get new injectors (I do not know how to test them), I put some LUCAS fuel injector cleaner and a full tank of gas then hit the road. It runs great as long as I keep the RPM's above 1000, cruised down the interstate at about 80mph and it ran awesome, got home and let it idle and it started to miss again. I guess I will try and run some more fuel through it tomorrow and see what happens.
Any ideas are welcome.
Thanks again,
RB
Old Dec 29, 2007 | 05:59 PM
Audi_Skydiver's Avatar
Hey, I have some injectors from my car that I will sell to you cheap if you want them. They came out of a perfectly running 99.5 a4 1.8t engine. I'm notbsure if they will
work in your car though. Anyoneknow if they will?
Josh
Old Jan 3, 2008 | 08:32 PM
rbflip's Avatar
Just wanted to say thank you to everyone that gave possible solutions, it is finally fixed today. Found a one way valve on the back of the intake that had a crack in it, replaced and runs awesome now.
Thanks again,
RB
Old Jan 4, 2008 | 12:30 AM
feerocknok's Avatar
Was it a one-way valve for vacuum? I was going to suggest the fuel filter
Old Jan 4, 2008 | 03:48 PM
rbflip's Avatar
It was a one way valve part number 058-905-291-k
RB
Old Jan 4, 2008 | 04:23 PM
JETSPEED333's Avatar
SoCal Crew Member
pvc system?
Old Jan 4, 2008 | 11:01 PM
  #18
rbflip's Avatar
It was a one way valve coming off the back of the intake, not exactly sure what it went to. The car would not idle and was throwing misfire codes on random cylinders. I found the leak by checking all the hoses I could get to and found that one leaking through a crack in the plastic housing, I grabbed it and the whole thing fell apart. Replaced the valve and it runs just fine now. I circled the valve in this pic, it is hard to see but hope it helps.
RB
[IMG]local://upfiles/47102/593D76B0AFEA4FC7808DD3321C6446A0.jpg[/IMG]
jgpdx
B7 Models
Oct 19, 2015 10:31 AM
jcs01a4
Jan 24, 2013 07:08 PM
Racerx220
Mar 7, 2010 08:06 PM
DSMKiller
May 3, 2009 01:27 PM
i3uddha
Sep 29, 2006 05:14 PM
