rattle from the both from wheels??
Old Jun 2, 2006 | 03:32 AM
Sp33d07's Avatar
Default rattle from the both from wheels??
everytime i go through a bumb i hear a rattle like sumthing is loose from both right and left front wheels. if i press and hold the brake while going through the bumbs it goes away what could it be?
Old Jun 2, 2006 | 03:34 AM
BadLuckAudi's Avatar
Default RE: rattle from the both from wheels??
control arms??
Old Jun 2, 2006 | 03:37 AM
miked's Avatar
ORIGINAL: BadLuckAudi
control arms??
Thatd be more of a squeek. Bushings or tie rod ends maybe?
Old Jun 2, 2006 | 03:38 AM
Sp33d07's Avatar
I TOOKS IT OFF TO TAKE A PEAK TODAY ACTUALLY THE SOUND ONLY COMES WHEN I HIT THE BRAKE DISK. IF I HIT THE SUSPENSION OR THE AXLE THERE IS NO RATTLE
Old Jun 2, 2006 | 03:58 AM
miked's Avatar
THEN RULE OUT ANY SUSPENSION COMPONENTS FOR NOW!! AHHH!!! YELLING!!
Old Jun 2, 2006 | 01:38 PM
acetrebo's Avatar
Well, you made the right call there already.
If it goes away when on the brakes, it sounds like it brake related.
When you took the wheel off did you see anything loose or hanging? Could you isolate the aread the sound was coming from? Are your pads worn or do they look ok?
Old Jun 2, 2006 | 01:45 PM
TT A4's Avatar
I had the same problem, I had my car inspected in May and they said I needed new rotors and brake pads after they replaced them there was no more noise.
woodstare
Jan 11, 2012 06:54 AM
Budcan
Jun 3, 2010 09:53 AM
chusaiyan
Nov 26, 2007 05:03 PM
MoritzCH
Jul 9, 2007 12:21 AM
dragondesigns
Feb 14, 2006 01:45 PM
