Rear ABS sensor - different types interchangeable?
Old Nov 29, 2006 | 07:04 PM
oppy's Avatar
Default Rear ABS sensor - different types interchangeable?
While doing a rear wheel bearing on my daughter's 2000 A4, I broke the abs sensor (actually it was rusted in-place and I couldn't get it to budge). Ordered a new replacement - part #8D0 927 807 C - and it's slightly different than the one I removed. The old one had a flat metal mounting plate with a hole which was secured with an allen-head bolt. The new one appears to friction fit, no bolt hole. Are these interchangeable, or did I get the wrong sensor?
Old Nov 29, 2006 | 07:32 PM
ProOnThaSnow's Avatar
Default RE: Rear ABS sensor - different types interchangeable?
I'd call your local Audi Dealer and ask them, It'd probably be easier, and quicker than waiting for someone to answer on here...
Old Dec 1, 2006 | 09:09 PM
dankhound's Avatar
Most likely you got the wrong sensor. There are both types on audis and i dont think they are interchangable.
Old Dec 1, 2006 | 10:34 PM
oppy's Avatar
Thanks for the advice. I checked and the part number is correct. I'm thinking maybe it was repackaged or something.
Old Dec 2, 2006 | 12:59 PM
dankhound's Avatar
Thats a possibilty. Is there a part number on the part itself. Ive even seen heads put in the wront box.
srod2222
May 2, 2011 04:45 PM
Boober
Mar 16, 2010 05:46 PM
wood_e
Sep 23, 2007 03:32 AM
