Rear Brakes - Advice
Old Sep 14, 2005 | 10:43 PM
5SpeedJazz's Avatar
Default Rear Brakes - Advice
Hey All,
I was wondering if after market rear brakes, pads and rotors are ok, or not?
Looking to possibly save $. I had a potential car (A4 2.8 Q) inspected by a relyable audi shop (not dealer), and the only things found wrong were the rear brakes were low (recommended to replace in a few months), and it needed an alignment.
I was told a rear brake job w/audi parts is in the range of $400-500. We're trying to minimize the overall initial cost of buying, etc..
Thanks!!!!!!!
Adam
Old Sep 15, 2005 | 02:34 AM
5SpeedJazz's Avatar
Default RE: Rear Brakes - Advice
Bump..
Old Sep 15, 2005 | 04:35 AM
flyboy's Avatar
unless your replacing every part, I'm sure you can get away cheaper thant that. check here.brakes
Old Sep 15, 2005 | 08:19 AM
david9999's Avatar
^^^^^ above. Parts should be a total of about 120 dollars. Labor should be in the range of another 100
Old Sep 15, 2005 | 08:48 AM
JettaRedII's Avatar
Mintex Red pads are very good aftermarket pads (about $55) and OEM rotors run about $100 a set. Look it up at www.ecstuning.com. You will need a special tool to compress the caliper pistons, so you are looking at about $220 plus your labor. The tool is just an upfront cost.
Old Sep 15, 2005 | 09:02 AM
JettaRedII's Avatar
Actually the tool is $35, the rear pads are $40 and the rotors range from $70 to $100. Here's the tool: http://www.ecstuning.com/stage/edpd/...ro&engine=1.8T
Old Sep 15, 2005 | 09:32 AM
5SpeedJazz's Avatar
So, I'm hearing that aftermarket and OEM are in fact ok, and no need to go with authentic Audi parts on (pads and rotors)? I like the prices I'm seeing already!
Old Sep 15, 2005 | 12:40 PM
beefski's Avatar
also try tirerack.com
they have brembo & powerslot rotors
and a good selection of pads.
used them 4 my other car, brembo rotors, fast delivery good price.
mrmike454
Aug 12, 2010 10:05 AM
spaceman3
Mar 3, 2009 08:00 PM
stutzdriver
Jan 24, 2009 11:22 AM
anmagro
Jan 9, 2009 06:04 PM
cbcustoms
Aug 25, 2008 10:55 AM
