rear differential seal
Old Oct 5, 2007 | 06:21 PM
vlado182000's Avatar
Default rear differential seal
hey guys does any one know how hard it is to replace rear differential seal on 01 a4 1.t q. It looks like its leaking on the right side. Or is it better to get it done by the shop... any information would help ..
Old Oct 5, 2007 | 06:38 PM
auditech79's Avatar
Default RE: rear differential seal
You need the correct press tool to get the new seal in, you can take it out with a small pry bar or screwdriver.
The only hard part is you have to support the rear diff with a jack and lower it down about 4-5 inches so you can pull the axle shaft out.
Old Oct 6, 2007 | 05:09 AM
david9999's Avatar
Alternatively, if it is a small leak, you can just check the differential fluid once a year and top up
DanaB6
May 31, 2012 09:41 PM
Djurynk
Feb 6, 2009 09:53 PM
varsh
Apr 16, 2008 12:36 AM
vlado182000
Oct 9, 2007 11:25 PM
shovin
Mar 14, 2007 07:03 PM
