rear differential trouble
Old Feb 11, 2007 | 01:20 PM
g60vdub's Avatar
Default rear differential trouble
I have a 01 a4 Quattro (113,000 miles)that is making a humming noise from the rear differential (loudest at 50 mph). Diagnostics so far: I put the car on a lift a spunthe back wheels, no noise was coming from the wheel bearings. I then spun the wheels as fast as I could and listened to the rear diff where I could hear a low clunking noise. I checked the fluid it was clean and only an ounce or two low. I am assuming that the bearings are going bad.
Questions: What commonly goes wrong in the rear diff? Where can I buy the bearings? What other parts should be replaced at the same time? What is the estimated cost of having this job done at a shop?
Thanks in advance…
Old Feb 11, 2007 | 03:25 PM
david9999's Avatar
Default RE: rear differential trouble
Never heard of one going bad. I'd drain the oil and replace it with fresh synthetic anyway.
Sure it isn't your fuel pump making noise?
Old Feb 11, 2007 | 03:41 PM
g60vdub's Avatar
Sure it isn't your fuel pump making noise? >
I could hear the noise with the car off spinning the wheels on a lift. The sound was coming from the diff 99% sure.
Old Feb 11, 2007 | 03:45 PM
techbod's Avatar
bearing noise by what you say ( it will only be audible under load ) so jacking it upevades the problem, im going bearing
jma
Aug 23, 2010 09:07 AM
peter121
Jun 7, 2010 10:48 AM
cristilucu
Nov 24, 2008 03:03 PM
225tt
Jan 22, 2007 07:05 PM
mikehh
Aug 17, 2004 12:29 PM
