Rear Drivers Side Window
Old Oct 21, 2005 | 05:26 PM
TheWordsWithin's Avatar
Default Rear Drivers Side Window
I'm having a problem with my rear drivers side window. When you click the button down it goes down about half way and stops. Then if you pull it up, it goes up a little bit and falls back down. If you keep toggling it up it will finally pull up with a struggle. What is interesting about it is that while youre doing this, there is an awful noise. Almost a crunching sound. I don't really know what this is, but I've heard it might be a window guide, a cable regulator, or the whole motor, or just be oiled. If anyone can help me on this, it would be greatly appreciated. By the way it's a 99 A4 1.8T Quattro. Thanks!
Old Oct 21, 2005 | 07:59 PM
jja2.8's Avatar
Default RE: Rear Drivers Side Window
yep sure sounds like you need a cable regulator. http://www.ecstuning.com/stage/edpd/...egory=Interior
if you can figure out how to take the panel off, you can most likely do the install. i'm pretty sure you will need to drill out some rivets to remove the old regulator.
Old Oct 8, 2007 | 04:57 PM
nayaudi's Avatar
Im having a similar problem... I took my panel off and realized the cables were unwound from the spool... Is there any way to rewind them back onto there?
Old Oct 8, 2007 | 05:12 PM
A4speed's Avatar
ORIGINAL: nayaudi
you can try manually, but if the plastic piece is broken then you just have to buy a new window regulator, ive had to change 3 of them on my car.
Old Oct 8, 2007 | 05:47 PM
nayaudi's Avatar
Nothing is broken... they just came off the spool and are a lil kinked... is there any way of straightening them?
Old Oct 8, 2007 | 05:49 PM
EliteTuning1's Avatar
same thing happened to mine nothing broken but kinked, i could not straighten it out so i bought the regulator but have not put it on yet because it is a pain. so i ziptied my window shut for now
Old Oct 8, 2007 | 05:56 PM
nayaudi's Avatar
Im thinking about buying the same type of cables and same type of connectors and replacing them myself... the reg. is 100 bucks and I dont want a non functional window haha. Its a bitch to wind them back up on the spool though.
Old Oct 8, 2007 | 06:50 PM
A4speed's Avatar
yeah, thats the only way to do it. i would just buy a new window regulator, tear off the door panel and put the new one on.
Old Oct 8, 2007 | 06:54 PM
nayaudi's Avatar
actually... I got it!!! it was a bitch but i finally wound it up and tried it a couple times... works fine... now Ive gotta do the back window! ****!
Old May 15, 2010 | 06:26 PM
PXA4's Avatar
So does anyone know how to get the top mounting screw out of the regulator to remove it? I'm replacing my passenger side rear window regulator and can't figure out how to get to the top screw that holds the regulator in.
Any help with this would greatly be appreciated!
TIA
TurboRhatt
Apr 2, 2008 12:43 AM
dafowler88
Jul 11, 2007 08:45 AM
preyash
Oct 29, 2006 11:16 PM
1986gtcoupe
Oct 17, 2006 08:59 PM
