Rear Light Bulb Replacement
This might be a stupid question
. I have an A4 2003 Quatro and the rear right light bulb went off. I want to replace it myself, but I couldn’t get the assembly off. I found a screw (the one in the trunk) and after I get this screw out, the assembly is about to come out but it looks like something is holding the assembly. Is there another screw?
Thanks
[IMG]local://upfiles/30531/5CCA2E215874419BA9E1B4EF9F9841D5.jpg[/IMG]
. I have an A4 2003 Quatro and the rear right light bulb went off. I want to replace it myself, but I couldn’t get the assembly off. I found a screw (the one in the trunk) and after I get this screw out, the assembly is about to come out but it looks like something is holding the assembly. Is there another screw?Thanks
all you have to do is gently so not to break any of the mounts is pull from the outside cornerof the light in. you can also push in on the screw hole to help nudge it out
02, 2003, 2007, a3, a4, audi, bulb, bulbs, bulf, convertible, light, rear, replacement, replacements, tail
