rear pads
Old Dec 30, 2006 | 11:54 AM
sandman's Avatar
Default rear pads
doing the rear pads today, is the spin type compressor necessary, or can i just spin it w/ some needle nose?
also i want to know what i am saving by doing it my self. i dont care what the dealer would charge because im sure its way too much. but what is a reasonable price at like a lesschwab or some indypendent mech.
Old Dec 30, 2006 | 07:09 PM
tractioncontrol's Avatar
Default RE: rear pads
Yes you need to rotate the piston as is returns. Usually you can rent the tool at auto parts stores for a refundable deposit or buy them for about $100 there also (at least around here you can).
Old Dec 30, 2006 | 08:28 PM
Trey25's Avatar
The piston tool helps alot but the piston is really easy to rotate so a needle nose will work fine.
Old Dec 30, 2006 | 08:33 PM
wood_e's Avatar
The caliper piston tools (the nice ones) can he had at your local harbor freight store for under $25. They're a lifesaver. The cube tool is widely available too at about $10. A needle nose will work, and to make it easier open the bleeder a bit.
Old Dec 31, 2006 | 02:26 PM
sandman's Avatar
ORIGINAL: tractioncontrol
thanks, i realize this
ORIGINAL: Trey25
cool thats all i needed to know even though im done now. i wound up buying one of those cube things, it worked well.
Old Dec 31, 2006 | 04:25 PM
TheJazz7's Avatar
Man, I bought one of those cube things, and it didn't freaking fit! I got mine from Advanced Auto Parts, where'd you get yours?
Nobody around here rents the retractor tool
Old Dec 31, 2006 | 04:35 PM
JP A4's Avatar
i got mine from harbor freight, its a bitch to turn, so lube it well, then ur golden
Old Dec 31, 2006 | 04:38 PM
techbod's Avatar
my choice and no problems you just need to push the piston inwhen turning clock wise of course
http://images.google.co.uk/imgres?im...lr%3D%26sa%3DN
[IMG]local://upfiles/12092/97AA8F0DF71F4E3FAA10C95796E42ED7.jpg[/IMG]
Old Dec 31, 2006 | 08:20 PM
duburban's Avatar
grab the tool off ebay for $25. i did it without the tool and spent an hour pusing those things in. w/ the tool it took less than a minute. i bought the cube before hand... thing was useless, i brought it back and the guy said "i guess no one told you those things don't fit any car". make sure you take the guide pins out, wire brush em and slap on some new grease. i just had one that siezed and screwed up the pad contact.
OldAudiA4B5
Mar 13, 2015 10:39 PM
paaudia6
Sep 23, 2009 09:35 AM
pilot5.0
May 19, 2008 09:50 PM
feerocknok
Apr 1, 2008 10:37 AM
siembad13
Feb 8, 2006 11:00 PM
