Rear Wash Wipe
Old Dec 11, 2006 | 09:19 AM
murkyhorse's Avatar
Default Rear Wash Wipe
Hi there!
I have an Audi A4 Estate and the Rear Washer does not work.
I have confirmed that the Pump definitely pumps water.
I have confirmed that there is no water being delivered to the wiper assembly on the rear door.
I can confirm that water disappears from the washer bottle when the pump is in operation.
This means that the Washer pipe has been disconnected somewhere and the Washer fluid is flooding the interior of the car!!! :-(
However, I cant see where this is happening, I have found no wet patches or puddles under the car.
Can anyone confirm the routing of the Rear Washer pipe so that I can trace it back? Has anyone else had this problem?
Cheers,
Stuart
Old Dec 11, 2006 | 09:43 AM
techbod's Avatar
Default RE: Rear Wash Wipe
the pipe runs to the rear door where the hinges are and its not uncommon for the pipe to break there with use
Old Dec 16, 2006 | 06:49 PM
dankhound's Avatar
Also check by the drivers dead pedal. Ive seen it come loose there and it wont show on the carpet.
Old Dec 18, 2006 | 07:25 AM
murkyhorse's Avatar
Thanks for that. Would that be on a Right Hand Drive car? I am assuming you're a Left Hand Driver?
Cheers,
Stuart
Old Dec 19, 2006 | 01:33 AM
dankhound's Avatar
Indeed. For a right hand drive i would assume they run it in a similar location. Not really sure which side thou. I would image the entire car would be a mirror image or close to it, so that would put the hose near the gas pedal.
hidnmine
Mar 21, 2015 12:20 PM
a6ontrack
Nov 3, 2013 04:04 PM
big_nige
Oct 6, 2011 02:25 PM
starhannes
Mar 8, 2008 05:58 PM
fbridge
Jul 10, 2007 08:16 PM
