Rear window
Old Feb 25, 2006 | 06:18 PM
Jeppe81's Avatar
Default Rear window
Hi Guys!
This is my first post at the forum which I have got good tips from but now I have a problem that I can't solve.
My passenger side rear window is not working. I have replaced the window motor and the switch but it is still not working. The window is all dead even though you use the switch in the front or the rear. All the other windows are working fine.
I know there are a lot of posts about this topic but I can't seem to figure out the problem.
Please let me know if you have any suggestions?
Thank you,
Jeppe81
Old Feb 25, 2006 | 06:59 PM
tip5's Avatar
Default RE: Rear window
The window regulator is probably out of line or the clips and the assembly is done.
Old Feb 26, 2006 | 03:49 PM
dankhound's Avatar
When you use the switchs does the motor turn. If not you have an electrical problem. Otherwise you have regulator issues.
Old Feb 28, 2006 | 03:57 AM
Jeppe81's Avatar
The motor is no turning. It is all dead but it has been changed so I guess it has to some wire or regulator issue.
WyomingGuy
Jul 21, 2012 08:54 PM
Jester008
B8 Models
Aug 8, 2011 08:34 PM
DavidgotanAUDI
Dec 12, 2007 11:10 AM
coby1856
Jan 25, 2007 02:07 PM
burc_o
Feb 3, 2006 01:19 AM
