Just thought I would share my experience with others... especially newbies like me!! Obviously all the usual caveats apply... dont try this if you cant handle a screwdriver etc...
I have just replaced the electric window switch on my passenger side door. I suspect the process would be no different on any other.
First off this is a UK 2001 A4
Step One
First remove the two screws marked 1 and 2.
Screw 2 is found inside a small hole under the grab bar. I stuck some BluTack to the end of my screwdriver to ensure I didnt drop it anywhere.
Then pull the trim nearest the front of the car towards you. It pops out by an inch or so and then slide the rest of the trim to the right to unlock it and it then pulls off.
[IMG]door1.jpg[/IMG]
Step Two
Place a mat on the ground under the door. Avoids damage to plastic trim.
Having removed the trim, remove the 4 screws that have been revealed. (1)
Then at the bottom of the door prize the panel away from the door. (2) Once started you can use the grab bar to pull more firmly and also to lift the top of the panel up so it unlocks from the window.
[IMG]door2.jpg[/IMG]
Step Three
Unhook the door catch cable and pull it from the restraining collar
The door can now be gently rotated and placed on the mat.
[IMG]door3.jpg[/IMG]
Step Four
There are several electric cables which you could unclip but this is not necessary unless you want to completely remove the panel. To replace the electric window switch this is not necessary. Simply locate it on the underside of the panel and pull gently down. It will pop out easily (1). Then unplug the switch (2) and replace with the new one.
[IMG]door4.jpg[/IMG]
Step Five
Simply reverse the above proceedure to reassemble everything. Total time about 20mins. Only tool required is a philips (cross head) screwdriver. The last picture shows the old and new switch in place.
.... and it even works;-)
Hope this is of help to people.
[IMG]door5.jpg[/IMG]
[IMG]local://upfiles/6650/C8653820663E48ABB3A3C8D9286A289C.jpg[/IMG]
[IMG]local://upfiles/6650/58A83B25C3124DEBBC88596F44786D4E.jpg[/IMG]
[IMG]local://upfiles/6650/9B9A4EA92758485298416D5777537B2F.jpg[/IMG]
[IMG]local://upfiles/6650/D45B7D3A7D5F491FB2AD3BC1281C72E7.jpg[/IMG]
[IMG]local://upfiles/6650/F26B40D6514D4165BC3429FF36B76C59.jpg[/IMG]
Step One
Step Two
Step Three
Step Four
Step Five
the pictures aren't formatted right, only the thumbnails at the bottom show up...looks pretty good...you should also specify that you have a B6, for the brainless people out there...as there are quite a few.
No I didnt post in the DIY section... should I do that or will the moderator move it???
Wanted to get the pictures in the right place with the text but couldn't work that one out... is it possible??? But if you click on the thumbnails you do seem to get the full size images.
Anyway... hope its helpful to some people.
RE: Removing door panels and replacing windows switches
Hi Guys.
New to this forum and owned my 2002 A4 Avant TDi 130 for a couple of months now and I love this car!
Small problem - drivers door electric window switches were a bit tempremental and in a bit of a strop, I thumped them with my fist.
Result? Said switches disappeared into the armrest/doorpull - oh how I laughed - not!
The question is, how do I get the driver's side door trim off without damaging it as it's obviously different from the passenger side shown here?
A little help will save my embarrassment.
Thanks in advance.
McJim.
Oh, by the way, it's a UK spec car.
Thanks in advance.
McJim.
