Removing Winhshield Washers???
Old Dec 19, 2005 | 02:12 AM
Karl's Avatar
Default RE: Removing Winhshield Washers???
no not really.. but just pull the hose off and you will be fine
Old Dec 19, 2005 | 03:45 AM
sandnsnow24's Avatar
Whenever you think you're getting riced at just look at my yellow car and feel better about yourself cause i get it all the time.....just cause it's yellow!!!! so i tell them to suck it and then make em feel bad about themselves when i show em my fine german engineering and how it can stomp on them even though it's pretty much stock except suspension.
I think those lights look kinda cool sometimes btw but are kinda anoying cause you see them all the time
Old Dec 19, 2005 | 09:03 PM
98 A4 Turbo's Avatar
lol well they can alwats be removed. Im gonna go try it now. Ill let u guys know how it goes. Thanks for the help!
Old Dec 19, 2005 | 11:35 PM
that was nooooooooooooo good. The jets did not want to come out and there were wires running to them. (I assume these are for heat but does n e one kno for sure??) And to make matters worse, one of my fog lights blew out while I was trying to hook the led's up to it because your not supposed to touch those bulbs or whatever. So... it was not a good experience and i dont recommend going after those jets for any reason. Thanks for the help anyway all.
--Matt
Old Dec 19, 2005 | 11:59 PM
Yuikio's Avatar
The car gods frown on what you were trying to do....
Seriously, it can't be that hard. Have some patience and some confidence.
My driver's side one is fxxxed; the actual squirter on the left side as you look at it from the driver's perspective (the jet that actually washes where you need to look out) so I need to switch it out, probably just change it to the passenger side, so I'll probably be tackling that as soon as the temperature gets to a reasonable level here. I'll let you know.
Old Dec 20, 2005 | 12:28 AM
Default RE: Removing Windshield Washers???
ull see yuikio. Its not that easy. It would be except for those two wires. They look like they can be disconnected but I am not sure. I wasnt going to go hacking away at that though because i dont know that much about the car and Im not trying to break stuff lol. Having too much confidence can be a bad thing. So i went ahead and put everything back to normal (Minus a fog[:@])
But I would greatly appreciate it if you could get back to me when you do yours!!
Old Dec 20, 2005 | 02:13 PM
sandman's Avatar
just take off the bumper, seriously this is the easiest way to access the squirter.
DJTR
Feb 27, 2008 06:12 PM
bontyal
Jan 11, 2006 08:13 PM
thintzen
Feb 12, 2005 01:30 AM
Auditwins
Feb 6, 2005 11:22 AM
