Replaced my Secondary Air Pump last night
Old Jan 20, 2006 | 12:50 PM
  #21
ryanmcell's Avatar
Default RE: Replaced my Secondary Air Pump last night
which cel code is this that it gives?
Old Jan 20, 2006 | 12:58 PM
  #22
Jestnomen's Avatar
6th Gear
ORIGINAL: onepoint8tee
What is its purpose then?
It injects fresh air into the exhaust so that unburned hydrocarbons are burned
Old Jan 20, 2006 | 01:30 PM
  #23
clconversion's Avatar
it is pretty simple just find a hose big enough to go onto the combi valve take the hose off that is there that goes to the secondary air pump clamp down your new hose and stick a little breather filter on the end of it not sure if this will caise i CEL yet or not I know guys on www.audizine.com have this done
  #24
this is also on cold starts only
ORIGINAL: Jestnomen
Old Jan 20, 2006 | 01:32 PM
  #25
ryanmcell's Avatar
secondary air pump wouldnt be the cel for the secondary air injector would it?
Old Jan 20, 2006 | 01:39 PM
  #26
what is the code ?
Old Jan 20, 2006 | 02:01 PM
  #27
goldenchild's Avatar
i had to plug the hole bc it wouldnt stay runin when i started it but i also had my maf unplugged(i can do this though bc im dbw) i havent tried it since i hooked the maf up might try that today
Old Jan 20, 2006 | 02:47 PM
  #28
i had my MAF unplugged for a while also it was running rich as hell and definetly got a CEL also would barly stay running but when I plugged the MAF back it it was fine
Old Jan 21, 2006 | 05:27 AM
  #29
brrman's Avatar
secondary air injector = secondary air pump.
You will, in all likeliness, get a perm CEL if you remove the pump completely. The system with throw constant Secondary Air Injection codes.
Old Jan 21, 2006 | 03:08 PM
  #30
ryanmcell's Avatar
what part number is the secondary air pump?
