resetting throttle body
Old Dec 30, 2006 | 10:31 PM
nyaudia498's Avatar
Default resetting throttle body
How do you reset the throttle body on 1998 audi a4 automatic/tiptronic
Old Dec 31, 2006 | 02:35 PM
sandman's Avatar
Default RE: resetting throttle body
turn the key to on position but dont start the car. it should reset its self in a few minutes.
Old Dec 31, 2006 | 02:37 PM
techbod's Avatar
do not touch the accelerator peddle this will scupper it ( ignition on and leave it alone )
Old Dec 31, 2006 | 04:12 PM
CRAZYHAWK's Avatar
Must have Drive By Wire car. Disconnect the battery and do what
they, above said.
Old Jan 1, 2007 | 01:34 PM
dankhound's Avatar
Theres still a basic setting for non dbw, for the idle control.
Old Jan 4, 2007 | 12:07 AM
nyaudia498's Avatar
what is a drive by wire car and how long do i wait after i disconnect the batery and turn the key to the on postiion. also is the car actually on when in on position.
Old Jan 4, 2007 | 12:33 PM
docurley's Avatar
Make sure you have your stereo code if you disconnect the battery as you will need it.
Old Jan 4, 2007 | 01:22 PM
Pson's Avatar
Or you can just pull the ECU out for 30 mins and then do the key thing...nothing else will work for the ECU will still be connected to the car and still keep the current fuel trim logs. Don't disconnect the batt that won't do it.
Old Jan 4, 2007 | 01:42 PM
nyaudia498's Avatar
how do i pull out the ecu
Old Jan 4, 2007 | 02:28 PM
NuYorka103185's Avatar
okay I'm not looking to do this, but this is the most confusing thread I have ever seen. Pull the battery, no pull the ecu, you need the stereo code, you can only do DBY, you can also do non DBY. Whoa!
