rim size
I think 19's should be alright. I agree, 20's would probably work, but tires would have to be soo low pro a little pot hole or something will bend, or worse, crack a rim. 19's should hopefully leave you with enough sidewall to give you a little cushion.
My buddy has an 06 S4 and it came with 18's stock. I would at least go up to 19's preferably 20's. You can check on tirerack.com they will give you what tire size you would need fit 19's or 20's, if the tire is not too small I would definatly do 20's. His S4 came with pretty big tires, the B7's have a much bigger wheel well.
discount tire direct show's
zero available for 20's
only four wheels for 19's
I would say go with 18's for ride quality - if you lower the car and have super low-pro's then your going to have a crapy ride.
Tirerack.com has a lot more available for 19's. If you insist on 19's then I vote for 19's RS4 Reps
